HAL.PBB.SendCndtMsgFail
Description
MM failed to send a conduit message to IOB. This may affect the PBB configuration because the IOB is not in sync with MM.
Remedy
Check if all the IOBs in the slot are operational. Undo and redo the configuration to push the configuration to the operational IOBs.
Severity
Debug-Summary
Message Text
Fail to send conduit message to %mesgType% to %slot% in %info%
Message Parameters
Name Type
mesgType String
slot Slot
info String
Applicable Platforms
